dunghp6315 (25-03-2008), new (09-03-2008)
bro nào dùng o2 zinc wm6 có thể sử dụng sim manager này dể wan lý contact
MobilityFlow Touch Commander v3.0.0.55
Requirements: Windows Mobile 5, 6 Based Device, .NET Compact Framework 2.0 (download) (embedded into EXE installation, for Windows Mobile 5 only)
Overview: Touch Commander lets you browse and scroll a Windows Mobile Pocket PC with a sweep of a finger across the screen just like an iPhone or TouchFLO. With just a touch, you'll be able to make quick calls to photo contacts, start applications, browse folders, get and send SMS, view photos and video, etc. Key features include full customization of interface elements, a Full Screen mode, and animated transition effects between screens.
Key Components
Key Components
* Touch Control - scroll lists, open and minimize applications by finger sweeps
* Today Plugin with clock, weather, launcher and more
* Cube-like Multipage Launcher
* Finger-friendly Start Menu
* Titlebar Battery Indicator
More Info: http://www.touch-commander.com/
Download Instructions:
http://www.4shared.com/file/38849255/86d87472/MobilityFlowTouchCommanderv30055XScaleWM5WM6SyMPDA .html?dirPwdVerified=b5d07a45
Mía ơi là Mía, bao giờ lớn bố cho đi dự SN GSM nhé! Toàn các anh cao to đẹp trai con ạ!!
hoangtri88 (26-02-2008), Minhtrung82 (15-03-2008), timkecuopmo (02-09-2008)
VITO Technology RingtoneEditor v1.22
Requirements: XScale WM2003 WM5 WM6
Overview: VITO Ringtone Editor is the quickest way to create your own ringtones. All you need to do is listen to the melody and choose the part of it you want to assign as a ringtone. User-friendly intuitive interface simplifies the process greatly. After you have started VITO Ringtone Editor, browse the folders to find the necessary music file in MP3 and WAV format and start playing it. While the melody is playing you mark the beginning and the end of a ringtone: just a matter of two presses. The ringtone is created! Now you can immediately assign it as a default ringtone or just save it. You can also replay the ringtone and if it doesn't meet your expectations you can play the original file once again to select a different part. Create your own collection of ringtones with ease!
# Just 2 button presses to create a ringtone
# immediate ringtone assignment
# Wav, mp3 music formats
# stylish interface
# fast forward and rewind with joystick while creating long ringtones
# pause before playing to capture song from its very beginning
# many ringtones from the same file, no overwriting
# optimized sound quality
# rename newly created ringtone
# ringtones have the same quality as the original file (files with lower quality are not optimized and take less space)
# if a new ringtone is quiet RingtoneEditor enhances its loudness so that you can always hear when people call you
# detailed help
# set the exact start and finish positions for your ringtone
# the slider showing the song progress has become more informative
Download:
http://www.4shared.com/file/38851097...ified=b5d07a45
ntn66 (15-09-2008)
PhoneAlarm v1.66.1
Requirements: Windows Mobile 2003/SE/5/6 Phone Edition PocketPc.
Overview: phoneAlarm is a Today screen plugin - giving you total control over your Pocket PC Phone. Never miss an important call, SMS or Email again. Automatically switch profiles and quickly access Inbox, call history and control the state of bluetooth directly from the Today screen. Optimised for one-handed and in-car use.
Fixed in v1.66.1 [Build 222] (23rd February 2008)
Improvements to stability
Fix vibrate lock-up on profile switch with "profileChangeNotify" option on some devices
Cancel in timed-lock/mute dialog now works for 12 hour format
Improve File Browser
Download:
http://www.4shared.com/file/38851970...ified=b5d07a45
kijuto (15-04-2008), Minhtrung82 (26-03-2008)
MASPware CheckList 2008 v5.01.2
Requirements: WM2003SE /WM5 /WM6
Overview: Using MASPware CheckList you can easy, fast and comfortable administrate all kinds of checklist. Starting from your shoppingcart up to a subject list for your next meeting.
You are supported by a Desktop PC program to edit your lists quick and easy. Furthermore, CheckList provides exporting and importing lists and data records to and from Pocket Outlook.
* Easy, fast and comfortable
* Administrate unlimited number of lists
* Unlimited number of listentries
* ViewMode for realistic view
* Categorized lists
* Listnotes
* Treeview
* Auto-Update Option
* Desktop-PC tool for editing (Microsoft .NET Framework necessarily)
* Backup-Function
* Desktop synchronisation
* Import and export of outlook-textnotes
Download:
http://www.4shared.com/file/38944475...ified=b5d07a45
ktonynguyen (28-03-2008)
bác Namfat cho e tìm hộ e: Zoomboard có cr@ck thì, thanks bác nhiều!
Cập nhật phiên bản mới 0.15:
-Thêm điều khiển âm lượng bằng phím cứng lên xuống (DPAD Up/Down)
-Thêm album art nhúng ID3
-Giảm thiểu dùng CPU khi thu nhỏ
-Fix lỗi tên tập tin thỉnh thoảng không thích ứng khi chuyển bài
http://www.4shared.com/file/38890073...P-015-WM5.html
PalmarySoft SmartSMSFilter Light v1.2
Requirements: WM2003, WM5
Overview: SmartSMSFilter Lght - the small and easy in use program which will allow you to accept, silent accept or dismiss incoming sms
SmartSMSFilter Lght - the small and very intuitive in use program which will allow you to control incoming sms receiving and isolate bulk and unwanted messages.
To any person or phone number from your Contacts you can assign one of three actions on incoming sms:
Accept sms with a signal (standard case);
Accept sms without any signal;
Block sms;
These actions also may be assigned to all undefined numbers and all numbers which are not present in your Contacts.
More Info:
http://www.mobiletopsoft.com/pocket-...light-1-0.html
Download:
http://www.4shared.com/file/38945231...ified=b5d07a45
Của bạn đây.
http://www.4shared.com/file/31502745...ified=b5d07a45
Lưu ý lần sau post bài này vào Topic yêu cầu phần mềm nha.
Đây là Topic những phần mềm mới cập nhật mà bạn.
WinMobile Download Accelerator (WMDA) 1.83
Description:
WinMobile Download Accelerator (WMDA) is an optimized Internet file download manager for Windows Mobile 2003/2003SE/WM5 ([COLOR=blue! important][COLOR=blue! important]Pocket [COLOR=blue! important]PC[/color][/color][/color]). The multithreaded technology implemented in this application will deliver to you a total new download experience and bringing you to the next level of Internet downloading. WMDA improves the speed with which you can download files from HTTP/HTTPS/[COLOR=blue! important][COLOR=blue! important]FTP [COLOR=blue! important]servers[/color][/color][/color]; It provides simultaneous and smart download and it is integrated fully with Pocket Internet Explorer.
Seamless Integration with Pocket Internet Explorer
WMDA is fully integrated into the Pocket Internet Explorer (PIE). It intercepts PIE download and provides additional features such as multiple files download, smart download that supports suspend-resume and restart an interrupted download from the point at which it was interrupted. WMDA will let you take advantage of a more reliable, faster, and optimized download.
Accelerated Downloads
WMDA splits a file into segments and download them simultaneously. This process noticeably increases the download speed. It supports up to eight segments per file.
Simultaneous Downloads
WMDA is capable of simultaneously downloading up to ten different files. However, the number of simultaneous files defined in the transfer manager affects the download speed. The [COLOR=blue! important][COLOR=blue! important]processor [COLOR=blue! important]power[/color][/color][/color] of your mobile device and your connection bandwidth also define how many simultaneous download that could be implemented.
Download http://www.4shared.com/file/38971130/ebe618b8/WMDA.html
Bookmarks
