FPT
Chủ đề đã khóa
Trang thứ 40 trong số 199 Đầu tiênĐầu tiên ... 30 38 39 40 41 42 50 90 140 ... Cuối cùngCuối cùng
Hiển thị kết quả 391 đến 400 trên tổng số 1988
Chủ đề: Phần mềm dành cho Pocket PC (cập nhật mới)-Phần 2
  1. #391
    Respected Admin namfat's Avatar
    Ngày tham gia
    Aug 2005
    Đến từ
    Thanh Xuân, Hà nội
    Tuổi
    31
    Bài viết
    4,347
    Thanks
    1,012
    SKTools updated to version 3.1.9 [09-Aug]
    Powerfull maintenance toolkit. Cleaning the registry and the file system, FreeUP RAM, other methods of system maintenance and much more...
    Cleaning:
    * Clear temporary and cache folders such as IE contents, IE history, Mail attachments, Terminal Server client cache, Opera cache, NetFront cache and custom user folders
    * Find and delete:
    o temporary, empty and absolete files
    o bad registry keys and values
    o empty registry keys New!
    o bad shortcuts
    o duplicate shortcuts
    o duplicate notify queue entry/entries
    o bad uninstall info
    o files depending on their size or/and names (wipe optional)
    o duplicate files (search by the name,size,crc)
    o MS Reader bookmarks (taking into account the bookmark's in-use/not-in-use status)
    o empty folders
    o past appointments
    * Delete PIE history (registry)
    Built-in Uninstaller:
    * Show the list of the installed programs including their size and date
    * Show the list of files and registry keys of the installed programs
    * Uninstall program
    * Save the installed programs list to a text file
    FreeUP RAM:
    This option can free up 50K-2M of RAM
    * Send hibernation message
    * Compact Heaps (WM5 only)
    * Imitate the "memory low" situation
    * Close tasks
    * Scheduler for silent background start
    System tweaks:
    * more than 70 tweaks in 10 categories
    Registry Explorer (New!):
    * Browse registry
    * View keys and values
    * Delete keys and values
    * Create new keys
    * Create/Modify values (REG_SZ, REG_MULTI_SZ, REG_BINARY, REG_DWORD)
    * Export (Unicode REGEDIT5)
    * Import (Unicode REGEDIT5, REGEDIT4)
    * Backup/restore
    * Search
    PIM maintenance:
    * Search for duplicate contacts, appointments and tasks
    * Show past and reccuring appointments
    * Delete PIM data
    Notifications Queue:
    * View, add and delete records
    * Find duplicates
    Backup/restore:
    * Auto (may be disabled) backup of a registry key prior to its deletion
    * Full system backup (may not work correctly in some cases with certain devices)
    * Sheduled full backup
    * Independent registry, filesystem, databases, PIM, ActiveSync Partnership, MSReader activation backup
    * Self backup
    * Password protection for the backup files
    * Find and restore all of the SKTools backup files
    * Good compression of the backup files
    Storage card maintenance:
    * Display the card'(s') info (size, ID, slack, ...)
    * Format, Scan and Fix (hardware dependent)
    * Empty
    * Rename
    * Other...
    Database maintenance:
    * Show the list of databases (CEDB, EDB)
    * Delete
    * Empty
    * Export/Import to/from an XML file (device and database dependent)
    Process list:
    * Show all the processes including the list of process' modules
    * Display the info of memory usage, threads, command line
    * Close one or selected processes
    Windows Startup:
    * Display the list of the programs run at the system's bootup
    * Delete program
    * Add new
    * Programs startup sequence management (device dependent)
    Automation mode:
    * Run SKtools at the system's bootup
    * Run SKTools every day at the user defined time (powering the device off after the operation is complete)
    * User defined operations list
    * Background mode (run in the background, just LED blinking)
    Other:
    * Registry optimization for WM5/WM6 New!
    * Windows services maintenance New!
    * CPU usage New!
    * Search and replace in Registry New!
    * Delete ALL contacts, appointments, tasks, messages option New!
    * Show Messaging Files New!
    * View and manage Today plugins
    * View and manage Input methods
    * View and manage SIM contacts (PocketPC PE)
    * View and manage SIM SMS (PocketPC PE)
    * Compact and purge call history (PocketPC PE)
    * System Information
    * Memory Usage - display all the folders including their sizes
    * Change the location of PIE cache, PIE history, PIE coockies, AvantGO data, NetFront cach, Messaging (outlook) files New!
    * System optimisation option
    * Soft and Hard(for certain devices) reset
    * Command line support (screen off/on,power off, soft/hard reset and more...)
    * Shortcut Wizard
    * Change system files' paths (you can move some dlls from the windows folder to any location, for example to storage cards)
    * Multi-language support ( English, German, Russian, Spanish, French, Italian, Dutch)
    * Free updates for all new SKTools 3.xx.xx versions
    * More...
    Download: http://www.4shared.com/file/21728072...ools-v319.html
    Mía ơi là Mía, bao giờ lớn bố cho đi dự SN GSM nhé! Toàn các anh cao to đẹp trai con ạ!!
  2. Các thành viên gửi lời cám ơn tới bài viết:
    banhbeom1 (29-11-2008), baomeo (11-08-2007), humiho06 (13-08-2007)
  3. #392
    Respected Member minhque's Avatar
    Ngày tham gia
    Dec 2005
    Bài viết
    21,604
    Thanks
    2,444
    DSE Technology NightSky v1.1-SyMPDA/COREPDA
    NightSky is an unique, innovative simulation of the celestial sphere providing 5 views both in landscape and portrait screen modes:
    Equatorial,
    Polar - North,
    Polar - South,
    Sky and
    Horizon view.
    Other features include:
    Navigate the NightSky using your stylus,
    Constellation selection screens,
    Zodiac symbol display,
    Realtime display of Sun, Moon and 7 Major planets,
    Acquire Position and Time from your GPS,
    Slave Horizon view to your GPS heading,
    Loadable named star dataset,
    Selectable files for stars, constellations and Named Objects,
    Scale lines for Horizon, Ecliptic and Galactic Equator.
  4. #393
    Junior Member hadaica2007's Avatar
    Ngày tham gia
    May 2005
    Đến từ
    tokyo
    Tuổi
    28
    Bài viết
    17
    Thanks
    Tuyệt quá bạn à. Cài cái này vào mà nghe nhạc thì mới thấy cái máy PDA của mình giá trị hẳn bạn nhỉ ?
    Trích dẫn Từ bài viết của namfat Xem bài
    WinVibe 2005 4.9.5 for PocketPC (QVGA)
    WinVibe Media Player
    WinVibe Media Player Features:
    1) MP3 / OGG / WMA / ASF / WAV format playback
    2) VU-Meter / Equalizer Spectrum / Oscilliscope display
    3) Edit Playlist and Save function
    4) MP3 / OGG / WAV / Playlist file Association
    5) Hardware button mapping
    6) Sleep Timer
    6) Surround / Bassboost / Reverb / Echo effects
    7) Play speed change
    8) Support Showing lyrics when playing music
    - ID3 Tag lyrics
    - LRC, TXT file
    9) HTTP streaming playback (MP3 / Ogg Vorbis) 10) SHOUTcast streaming playback (MP3 / Ogg Vorbis)
    Download here :
    http://cfs1.tistory.com/upload_contr...QVGA_4_9_5.exe
  5. Các thành viên gửi lời cám ơn tới bài viết:
    baomeo (13-08-2007), humiho06 (13-08-2007)
  6. #394
    Ngày tham gia
    Dec 2005
    Bài viết
    21,604
    Thanks
    2,444
    Killer Mobile BlackBaller v1.0 XScale WM2005 Smartphone2005
    (K+yg+n Read NFO-SyMPDA)
    Quite Simply the Most Effective, Easy To Use Call & SMS Filtering App On the Market
    ---> What it Does
    BlackBaller (tm) By Killer Mobile Software is an intelligent Call & Message Filter PLUS SMS auto responder for Windows Mobile Devices. BlackBaller is already the Best program of it''s kind for Series 60 (Symbian) Devices, and now we''ve pulled out all the stops to make it the best application of it''s kind for Windows Mobile Users.
    Feature List:
    * Filter Calls & Messages
    * Allows Creation of Blacklists (filter numbers on list) & Whitelists (all numbers EXCEPT those on list are filtered)
    * Optional Mute Ringer Feature (Instead of Blocking)
    * Complete Log & Date of Each Blocked Event, Including Blocked Message Text
    * SMS Auto Reply to Filtered Event (call & Message)
    * Private, Unknown & Unavailable Number filtering
    * Contact & Log Integration
    * Removes Blocked Call Log for Guaranteed Privacy
    * Create an unlimited number of lists for the ultimate in flexibility
    * Killer Mobile''s Patented "Smart Reject Feature" allows you to add new blocked numbers on the fly
    * Create lists from Contacts, Logs or Manually
    * Set Expiration Date of Lists
    * AutoStart on Device Reboot
    ---> How to Use it
    INSTALLATION:
    ---Install SDKCerts.cab to the device (included in zip)
    ---Soft Reset the device
    ---Install BlackBaller.cab (It is suggested to install this to your internal device memory)
    Note: SP user simply power off the device and power on and this will soft reset the device
  7. Các thành viên gửi lời cám ơn tới bài viết:
    az_click (05-10-2007), locle007 (22-12-2008), Ly Hoang Anh (13-09-2007)
  8. #395
    Ngày tham gia
    Dec 2005
    Bài viết
    21,604
    Thanks
    2,444
    SBSH MyList v2.1.06
    Requirements: Windows Mobile 2003/SE/WM5/WM6 PocketPc
    Overview: A feature rich and easy to use list manager. Create lists for any purpose that will help you bring order to your life! Create lists for your daily activities such as: grocery list, To-Do's, collections; Manage your professional lists for your frequent flights packaging, project development and more!
    Lists Manager
    # NEW! Manage your lists from the Today screen using new PocketBreeze integration!
    # NEW! View list progress status
    # NEW! Copy, Cut and Paste lists
    View all of your lists in a single view, grouped by categories
    Optionally assign custom icons to lists for easier identification
    View all lists located in a specific folder and use special top navigation box to change current displayed folder
    Import and Export your lists to common file format for PC use
    Full one-hand navigation support allowing complete list management using D-Pad navigation only
    Optionally define font size, font face and colors for category captions and list items
    Each list is stored as separate file for easy sharing and management
  9. #396
    Ngày tham gia
    Dec 2005
    Bài viết
    21,604
    Thanks
    2,444
    Bluetooth Audio Router v1.05
    Requirements: Windows Mobile 5 (Pocket PC) Bluetooth headset
    Overview: Bluetooth Audio Router automatically routes audio to your Bluetooth headset
    BTARouter automatically routes all audio output to your Bluetooth headset. You can play audio books MP3s, podcasts, application sounds etc, via your Bluetooth headset
  10. #397
    Ngày tham gia
    Aug 2005
    Đến từ
    Thanh Xuân, Hà nội
    Tuổi
    31
    Bài viết
    4,347
    Thanks
    1,012
    MASPware HandNotes v2.3
    Turn your Pocket PC into a virtual notepad! No notes-folder searches anymore! Browse your notes. Sheet by sheet. Like you would do it with a real notepad!
    Shoppinglists, meetingnotes oder a phonenumber during a walk...everthing is no problem! From now on, no keypad usage necessary! Use your handwriting!
    Features
    * quick and easy browsing (using icons and hardware-keys)
    * integrated notepad management (e.g. for serveral projects)
    * database import/export
    * QVGA and real VGA support
    * serveral pencolors
    * choose pen thickness
    * blank, cross-hatched and lined papers
    * page background colors
    * rubber
    * fullscreen-mode
    * minimize-mode
    * export sheet to graphics file for printing
    * send sheet via email on the go
    * exchange sheets using infrared port
    Download:
    http://www.4shared.com/file/21939655...Notes-v23.html
  11. Thành viên gửi lời cám ơn tới bài viết này:
    cutun_hoatay (14-08-2007)
  12. #398
    Ngày tham gia
    Dec 2005
    Bài viết
    21,604
    Thanks
    2,444
    Sprite Backup v6.0.2 Build 2065 PPC
    (Cr++ked-DRT)
    'Set and Forget' automated backups. Remote backup. Full desktop companion. The only solution with full WM 6 support. Unique upgrade mode for migrating to a new device.
    3 Reasons to choose Sprite Backup
    Unique Device Upgrade Mode - Restore to a replacement device or after a ROM Upgrade
    Support for Windows Mobile 6 Storage Card encryption - Access ALL your data after a hard reset
    Fully automated off-device Backups - Don't lose your backup file with your device
    Product Features
    Supports ALL WM5 & WM6 Devices - Smartphone AND Pocket PC
    NEW Backup to FTP Server - Now supports remote backup for additional protection
    Backup to PC - Increased protection by moving backups off-device
    NEW Sprite PC Manager - Easy setup & instant data protection
    Sprite Explorer - PC Tool for browsing and extracting backup file contents
    Upgrade Mode Recovery - Restore to a replacement device or after a ROM Upgrade
    NEW Support for WM6 Storage Card encryption - Access ALL your data after a hard reset
    Full & Custom Backup and Restore operations - offers complete control
    Self-Extracting Backup Files - Restore backups without re-installing
    Automatic Scheduled Backup - ensures up to date content protection
    Automatic Backup File Management - Optimize storage space used
    Requirements: WM5, WM6
  13. Thành viên gửi lời cám ơn tới bài viết này:
  14. #399
    Ngày tham gia
    Dec 2005
    Bài viết
    21,604
    Thanks
    2,444
    Opera 8.65 Build 2211
    (Cr++ked) - WM5
    Features
    Grab and Scroll (PocketPC only) NEW!
    Web search in address bar NEW!
    Save image NEW!
    Copy text NEW!
    Send link as e-mail, SMS, and MMS NEW!
    Import IE bookmarks NEW!
    Support for Macromedia Flash Player 7 for Pocket PCs NEW!
    FlashLite 2.1 NEW!
    Multiple Windows
    Tabbed browsing (Pocket PC only)
    Zoom
    Download
    Navigation and history
    Bookmarks
    Landscape/Portrait Mode
    Pop-up handler
    Padlock icon on secure sites
    User preferences
    Context menu
    Change encoding
    Desktop mode and Fit to Screen
    Plugin API (Netscape)
  15. Các thành viên gửi lời cám ơn tới bài viết:
    cafedang (19-08-2007), tsp (24-12-2007)
  16. #400
    Ngày tham gia
    Dec 2005
    Bài viết
    21,604
    Thanks
    2,444
    AvinaSoft QuickNotes v2.0 XScale Smartphone2005
    (K+yg+n SyMPDA)
    Simple and easy-to-use note taking application. You can create and manage notes directly on your smartphone. It comes with a QuickNotes Companion application that runs on your Windows Desktop.
    Create, edit or delete notes on the Smartphone.
    Manage your notes from your Windows Desktop using QuickNotes Companion.
    Categorize your notes by creating different categories.
    Bring your notes from your previous devices with ease by importing CSV files.
    Export your notes as CSV files, easy to port your notes to any application or device.
    Send or Receive notes from other Windows Mobile devices using Text Messages.
    Whats New in 2.0
    Manage your notes directly from your desktop using QuickNotes Companion application for Windows.
    Sort your notes by title, date or importance.
    Exchange notes with your friends and family by text messaging.
    Requirements
    Windows Mobile 5.0 Smartphone, 160kb free space
    Compatible Devices Cingular 2125 (5.0)
    Cingular 3125 (5.0)
    Dopod 557w
    Dopod 586w
    HTC MTeoR
    HTC S310
    HTC S620/621
    Motorola Q (5.0)
    O2 Xda Cosmo
    O2 Xda IQ
    O2 Xda Phone
    Orange SPV C600 (5.0)
    Pantech PN-820 Qtek 8300 (5.0)
    Qtek 8310 (5.0)
    Qtek 8500
    Samsung BlackJack
    Samsung SGH-i300 (5.0)
    Samsung SGH-i320
    T-Mobile Dash
    T-Mobile SDA U.S. (5.0)
    i-mate SP5 (5.0)
    i-mate SP5m (5.0)
    i-mate SPL (5.0)
    i-mate Smartflip
Chủ đề đã khóa
Tags cho chủ đề
Bookmarks
Quyền hạn
  • Bạn không thể tạo chủ đề mới
  • Bạn không thể trả lời bài viết
  • Bạn không thể gửi file đính kèm
  • Bạn không thể chỉnh sửa bài viết của mình
[Output: 119.21 Kb. compressed to 109.97 Kb. by saving 9.24 Kb. (7.75%)]
