eternal_faithful (28-11-2008), trieuvicasa (04-11-2008), vinhyen (04-11-2008)
WisBar Advance Desktop v2.0.1.1
What's new in WisBar Advance Desktop 2.0.1.1:
* Fixed a bug that could cause the notifier system to break.
* Added an option to the weather icon object to display the icon for the "Script Controlled City". This option is used in conjunction with the "Weather Previous City" and "Weather Next City" script commands. Also, it is used with the multicity weather text variables.
* Added script commands to move to the next or previous weather city. These commands are to be used with the "Weather Multicity" variables.
* Added a "Weather Multicity" set of text variables that display the weather information for the "current city". The current city can be either "Home" or "Visiting". This allows for future expansion of the number of cities for which weather can be monitored.
* Fixed a bug where the startup delay was improperly read causing the delay to be ignored.
* Made a change to make plugins resize properly when switching screen orientations.
* Fixed a bug where the program detected less than 64MB of RAM on devices that have more than 64MB.
* Added a commandline ("--profile=") to the Volume.exe process to quickly apply volume profiles without displaying the profile window.
* Added the ability to change the font on a contact grid.
* Fixed a memory leak that occurred when adding items to a grid.
* Fixed a crash that occurred when exporting a theme.
* Fixed a bug where the "Register" start menu shortcut did not register the program properly.
* Fixed a bug where event scripts were not being saved properly.
* Fixed a bug where the command to toggle Bluetooth between connectable mode would revert to discoverable mode when WAD was restarted.
* Fixed a bug in the touch-friendly volume dialog where the user would receive an error when dismissing the dialog.
* Made a change to make the SMS, MMS, Voice Mail and Unread Email information more reliable on certain WM 6.1 devices.
WisBar Advance Desktop v2.0.1.1 WM5 hoặc: http://www.mediafire.com/?nigtnjdwqnz
WisBar Advance Desktop v2.0.1.1 WM6 hoặc: http://www.mediafire.com/?m3emjzn4wyi
[ALIGN=CENTER]TouchLaunch 0.0.4.7 CAB file
[/ALIGN]
CAB file newly created for easy installation.
TouchLaunch is simple application launcher, which scans startmenu shortcuts, and list them alphabetically. This is very early alpha and my first program release.
Features:
-finger friendly scroll function
-quick alphabet shortcuts, either letterbar on screen edge, or abcgrid(similar to iContact )
-skinnable
-you can use todays' background image as this launcher's background
-supports custom icons ( 46 included in cab )
-you can categorize shortcuts in unlimited number of categories
-finger gestures to move through categories
left and right sweeps changes category
Change log:
[0.0.4.7][31 Oct 2008]
+alphablending
+support png icons with alphaLayers
+many Context Menu improvements, scroll if all the items can't fit on the screen
+Rearrenged optionDialog with folded/unfolded categories
+a brand new mainmenu
+menu background is darkened version of programs background image
+option whether it needs a tap or doubletap to launch programs
+Help menu,
Known "bugs":
-if you use .net2.0 version from zipfile, rename TouchLaunchNET2.exe to TouchLaunch.exe to get Replace folderview function to work
-icons doesn't show correctly in vga devices
-using today's background causes crash sometimes
Requirements:
.NET CF 2.0
wm6 ( might work with wm5 )
qvga or vga
Instructions:
Download and install the cab file, extract it to any
folder on your ppc (main or card ok) and run the exe file.
Uninstall previous version and then delete program folder it was installed, first.
Making new skins you can look example from premade skins in the skin
folder at installation folder. Adding new just copy your skin xml file
in the skins folder.
Custom icons can be added to iconpacks folder, just make a subfolder
with your favourite icons. Name them similar to shortcuts.
Example: Active Sync.lnk needs Active Sync.png ( or .jpg, .gif etc ) bitmap file.
Categories can be added by creating a empty file in the catogories subdir. And removed by deleting certain category file.
Link: http://www.mediafire.com/?mngjb4z4tjj
eternal_faithful (28-11-2008), hanoi7305 (12-04-2009), ngquangbien (03-11-2008)
Shamasi Notepad Mobile v1.1 and v1.3b
This is a "text editor" for Windows Mobile. It allows you to open text (.txt) files and other text based files (.xml, .bat, .log, etc.)K
Its main features being high speed, small size and compatibility with most devices running DOTNET Framework.
Updated v1.1: (28/10/2008)
Added Zoom Functionality
Reduced Executable Size!
Features:
Open/Create/Save text files
Supports cut/copy/paste by right click
Text input area resize as-per SIP (virtual keyboard) space
It is a standalone executable (no installation required)
Extremely light-weight and with minimum memory consumption
How to install:
Extract and copy Notepad.exe on your device and run it from there!
Developer URL: http://shamasis.net/projects/mobile/notepad/
I am attaching a BETA release of the 1.3 version of this software. Kindly test it and check whether it suits your "open-with" needs.
In general, it should work easily with the explorer you are using. In case it does not, try to use the under-mentioned open-with command.
The "open with" command should be: "/Program Path/Notepad.exe"
Where 'Program Path' is the path of the program and '%1' is the file name. Make sure they are within "double-quotes".
Link:
Final 1.1: http://www.mediafire.com/?yyiwzxnlctm
Beta 1.3: http://www.mediafire.com/?mjgjin5jgmy
eternal_faithful (28-11-2008), ngquangbien (03-11-2008)
dụng chụp màn hình trên PocketPC
Requirements:
PPC - WM2003, WM5,WM6.
NET CF 2.0
Features:
Supports screen captures in BMP*, GIF*, JPG, PNG formats (*not on all devices)
Add captions to screen captures
Obscure sensitive information in screen captures
Choose the saved image file name...
Link: http://www.mediafire.com/?mwmqyyjmbny
File Explorer Extension v.2.05
3`LnSbq
]UDb/s
Very useful "File Explorer Extension" >oMzP^9
Requirements: PC2003, WM5, WM6 ^/`}+ckq
#VHjN5]_
Overview: 69;xf;;_g
f6T`D2
When it comes to file operations, the default Windows Mobile File Explorer is quite limited. This is a freeware by Hou Ming that addresses all the missing features that should have been included in the Windows Mobile stock File Explorer. FS)8?(Dv
D<b+ fP,
Here are some of the fantastic “must have” features it adds: "-u{o1
l|6<= SF
# Resizable header for easy sorting by file name, date of last modification or size =wj3{I?S
# Tree view of folders; you can now jump easily from a location to any other on your device in one step 7<\cr
# Show extension option for those who ask themselves the same question I do: “What type of file is this QvjZV1$
# Icon view that enables the display of files as icons similar to your desktop computer ro #j)
# Real time image preview; now you don’t have to open several files in order to send the one you desire LWL[i6}H)z
# Open with Program allows you easily select an application to open the specific file you select (useful in case you don’t have the correct file associations or when you want Album app to open your images instead of Windows default picture viewer.) q SCq |
# File property context menu for easy renaming and attribute changing [!'Q}LD9
# Open all executables with Parameters in case you need a special parameter when launching an application #]e#&[=u
# Sending shortcut to Programs for instant shortcut creation of executables placed directly in Programs folder in Start Menu. vh\V4I H
D\~bn+
Download Instructions: wOB(m>Y
Copy Cab file to PPC and install in main. Takes only very little space. 'HN|+K
%cKY=7B-
http://www.geocities.co.jp/SiliconValley-Cupertino/2039/ w_8H0e-
woX9>V(o{
http://www.geocities.co.jp/SiliconValley-Cupertino/2039/fexploreext-jp.CAB p(g4x|3G
http://www.geocities.co.jp/SiliconValley-Cupertino/2039/fexploreext.txt
baby heo (13-11-2008), eternal_faithful (28-11-2008), JohnPaulsg (26-05-2009), sgking21 (04-11-2008), vinhyen (04-11-2008)
Picture Perfect 5.1
Phần mềm tạo hiệu ứng cho các bức ảnh,hỗ trợ các hệ điều hành.
Link: http://www.mediafire.com/?0llmy1tnzez
Phần mềm hiển thị đầy đủ ngày tháng, thời gian trên màn hình today chật hẹp chỉ với 1 dòng.
Thay đổi format hiển thị ngày tháng, thời gian.
Thay đổi font, kích thước, màu nền, màu chữ, độ trong suốt...
Hổ trợ các HĐH
Link: http://www.mediafire.com/?dzv1knmxx2v
hoangsy (04-11-2008)
MissedCallReminder
Nhắc nhở các cuộc gọi nhỡ, dành cho những người hay quên![]()
Vibrate and or generate a chosen sound at a set interval, to notify the user that there are missed calls or unread SMS messages.
Link: http://www.mediafire.com/?jmmzync4fyn
PowerSMS v1.2PowerSMS sẽ là công cụ đắc lực cho các những ai yêu thích sử dụng tin nhắn. Chương trình rất hay và có nhiều chức năng hỗ trợ cho việc gửi tin nhắn nhanh tới một ai đó, gửi theo nhóm, tự động gửi theo lịch biểu hay tự động gửi khi có cuộc gọi nhỡ
Hỗ trợ WM2005-WM06
Roll2Unlock v0.3 beta
Phần mềm xoay để khóa và mở khóa cho PPC
Hỗ trợ các HĐH và màn hình
Link:
VGA: http://uploads.bizhat.com/file/355270
QVGA: http://uploads.bizhat.com/file/355269
WVGA: http://uploads.bizhat.com/file/355271
Bookmarks
