Chủ đề đã khóa
Trang thứ 181 trong số 199 Đầu tiênĐầu tiên ... 81 131 171 179 180 181 182 183 191 ... Cuối cùngCuối cùng
Hiển thị kết quả 1,801 đến 1,810 trên tổng số 1988
Chủ đề: Phần mềm dành cho Pocket PC (cập nhật mới)-Phần 2
  1. #1801
    Quy ẩn giang hồ baotrung1305's Avatar
    Ngày tham gia
    Dec 2004
    Đến từ
    Ngõ nhỏ phố nhỏ ....
    Bài viết
    3,869
    Thanks
    492
    IGCalc 1.6
    IGCalc 1.6 GCZB2@(\
    IGCalc for Windows Mobile stands out from the variety of existing calculators presence of the following options (for which he actually was written): aP9qhhD$BE
    1. The phrase is introduced in full, as it is, and may be edited. $7/KU<_b7
    2. The result appears as you type. E2:kHJ!;Y
    3. Keep history imposed expressions. n#jZI
    4. It works with the clipboard (clipboard). yY<c'47
    5. It supports hexadecimal, octal and binary numbers as you type, and output result. x]h)5 `y
    6. It has a built-conversion core measures of length, weight, volume, temperature. )Evr9{yc
    7. He has built a calculator IP-subnets. $f/62 }Le
    8. Large buttons on the screen, you can easily click on the finger. A[!0hy
    The changes and additions in version 1.5: N+7YrT{X0
    - Support for the horizontal orientation of the screen in all modes calculator; Bp;v- _Ne
    - Support for Russian language (chosen through the settings); [?W/C.
    - Bit operation "not" and "or" exclusive or "; rz:q]ho
    - IP-subnet calculator understands the job subnet mask as a number of bits of the network, and in the form of octets separated; k?'-HC2g
    - Automatically detects the binary number in the IP-address and subnet mask; Z)OP4Hj
    - Added option "Copy results to the clipboard on exit; 5 Or!kj\
    - Fixed logic operations of calculating interest; 62^:rW9u
    - Miscellaneous fixes and bug fixes. bjY1XaGN
    The changes and additions in version 1.4: Y)G* |i
    - A new, more convenient to use without a stylus mode; 8'T^2g]CT
    - Increase the size of the keys; y} ****s'
    - Increase the font fields and the result; E>G` E
    - Support for soft keys WM5; A(S7pTSG4
    - Operation%, 1 / x, taking the expression in parentheses; 4y)UqOY
    - IP-subnet calculator for network administrators; m&*7Yv
    - Miscellaneous fixes and bug fixes. ?zC*}mU
    Calculating percent YP]\?Tu?h
    As users stand in the hat examples of calculating interest. `(!}{;
    The basic syntax is: x + y% v-95h=f
    Instead of the "plus" can be any sign of arithmetic: + - * / zh[3=$=*
    Means "to add x y% of x". 2U azqYD
    Calculated as: x * (1 + y/100) urlGyEF
    In the case of simple calculations per cent should be put brackets: x * (y%) JOQsK?t/
    Denotes a "y per cent of x" )VL./-A*J2
    Calculated as: x * y/100 70L >~%3d
    If you write without brackets, you get quite another - "x times y per cent of x". `zMj}~MS
    Examples: ga+TbyV`8
    By 200 plus 5% of the 200: teLi>e1
    200 + 5% = 210 c 5?$b\Ac
    200 multiplied by 5% from 200: /6bV(LR
    200 * 5% = 2000 xPC&/3
    Calculate 5% of the 200: +pPKO-i'
    200 (5%) = 10
    Link: http://www.2shared.com/file/4190678/...aigcalc16.html
  2. Thành viên gửi lời cám ơn tới bài viết này:
    eternal_faithful (28-11-2008)
  3. #1802
    Ngày tham gia
    Dec 2004
    Đến từ
    Bài viết
    3,869
    Thanks
    492
    CooTek TouchPal v3.5
    Phần mềm bàn phím dành chio PPC.
    Requirements: WM5, WM6>kmsM?=
    Overview: TouchPal is an innovative soft keyboard on Windows Mobile platform, powered by T+ input technology. Z!y{N%z
    f!'Xlm^j1
    W;yer2i
    4o+8C/K*
    Why TouchPal? i=MBE<w'
    It's Cool! Y}B7MIO9,
    "Flow" your keyboard by sweeping with your finger! ~@YcOJ
    Switch between three layouts: T+, Full-Qwerty, 9-key PhonePad. hJx)Y8Q_vx
    Resize your keyboard anytime! HOm#fI
    It's Easy! ~ !Wz^!0W
    Big buttons. Finger friendly. < 9Ye }Q
    Up to 300 chars/min, faster than your hard keyboard! QzSe1rR1f
    Input puntuations, numbers and uppercase letters without view switching Z7Gawe%
    It's Smart! )HA q%7|=1
    Powerful mistyping correction a$b2n]Y
    Clever prediction based on context r}"qmf t
    Predict next word Q/'Snz;Fd
    It's Innovative! ^&T;u0}
    T+ technology. Predictive + Precise. Cj]oFY
    Word association oqHrZt
    Super big dictionaries (40,000 English words, 140,000 French words...) |JTUPeKM
    It's Customizable! xidsm0V
    "My Sentences" with parameters (e.g., "See you in X mins") l(sY1g _o
    Customizable emotion symbols (e.g. , ^_^) P4@go<x2;
    You can develop your own layout or language pack with SDK tool. BwvI#u~
    K5N&4JR{
    What's new in V3.5? g8z}gR/TR
    "Flow" your keyboard - You can switch layouts or turn pages by sliding left or right on the keyboard. dgZyZtq 6
    Skins are supported - You can download different skins or design your own skins. 8'B$"+&r
    Press & hold - For those who don't like sliding, now you can hold a key to expand all the possible characters. U&XD_
    Change priority of a word in dictionary, or delete a custom word. <m%rH `$Ax
    Key press sound effect. ,pHm^m\X
    Prediction based on context - The prediction engine can now guess the word based on what you have typed. For example, if you typed "let" and then type for "us", the word "us" will appear prior to "is". {.m7?+)fn
    Next word prediction - If you typed "look", the word "forward to" will be shown in the candidate list. 'J2t ZJ(
    New Diamond skin (new in 3.5) FFf6\`
    Mixed language input (new in 3.5) - You can input multiple languages without language switching at all.  r](u]Ww
    Word combination (new in 3.5) - TouchPal can predict a new word by combining two existing words. e.g. "MySpace" yW}AQZ
    Quotation prediction (new in 3.5) - You can input "I'll" by typing "ill", "I'm" by "im". q$H\!1 m(
    Download Instructions: [4Ws pf%
    http://www.uploadjockey.com/download/6747910/cootek.touchpal.v3.5.ppc.incl.кεygεn.tyra.rar+BN0 <IK
    http://www.ziddu.com/download.php?uid=bbGflJSucbKcnOKnaKqhkZSsZaqcl5uo8 CmD>[P#:e
  4. Các thành viên gửi lời cám ơn tới bài viết:
    eternal_faithful (28-11-2008), haoatvb (12-06-2009), kisiri (05-11-2008)
  5. #1803
    Ngày tham gia
    Dec 2004
    Đến từ
    Bài viết
    3,869
    Thanks
    492
    GoogleNavigator 4.1
    Google Navigator is the most powerful and easy to use GPS navigation software on your Pocket PC. Also is the best and most easy to use and convenient software on your Pocket PC. All map data is transferred from Google via network, and save permanently on your device until you want to delete it. P_QWN"
    Goeo[^W_Z
    'gV)Qknj(
    *?f2m2
    Designed with productivity in mind, Google Navigator offers a quick and easy way to obtain the map and location information on your Pocket PC.With the most powerful functionality on map data operation and convenient user interface.You will enjoy the fun on your Pocket PC. ig?r2+_A
    2]f> 2
    GP `HN'~
    QRahm@W
    Key features cl5;]dW.sB
    Three view mode: Map mode, Satellite mode and Hybrid mode $A1D>#=
    Map can rotated in all 3D angle and move in all directions like Google Earth on your pc ^U9nHa04s
    Search the up to date location and business via network :&ItDz"(
    Pick some favorites locations to appear all in map U|:%S#MM"
    step-by-step voice and turn directions in GPS navigation aj]8&u
    3D street view allows you to quickly and easily view and navigate high-resolution, 360 degree street level images of cities in the world [6d9wXl"
    Tracking another's position in Google Navigator using the SMS tunnel,no network connection need! 2b0 <RH]
    Save the track line and load it in Google Navigator . wxgn+Y
    Convert track line to Google KML format and open it in Google Earth in PC -E C#8Rt
    Send the GPS position or the Selected position by SMS ,MMS and email. ! /rI6ly
    Add custom path and start GPS navigation.
    Link: http://www.2shared.com/file/4192497/...igator-41.html
  6. Các thành viên gửi lời cám ơn tới bài viết:
    eternal_faithful (28-11-2008), lekhai (31-10-2008)
  7. #1804
    Ngày tham gia
    Dec 2004
    Đến từ
    Bài viết
    3,869
    Thanks
    492
    SKTools 4.4.4(2008/10/31)
    Ứng dụng quản lý hệ thống mạnh mẽ,<tất cả trong một>cập nhật phiên bản mới.
    Changelog v4.4.4
    new "File Information" option
    improved "Clean!" option (not need 2nd rescan)
    "Shadow Services": added information about main service state
    "TuneUP!": added tweak for displays or hides the network time zone synchronization user interface on the Clock and
    Alarms applet (WM6.1)
    "TuneUP!": added tweak for disable SMS threaded conversation view (WM6.1)
    SKTools 4.4.4-WM5-WM6-QVGA. http://www.mediafire.com/?titmimlz2gw
    SKTools-WM2003-QVGA. http://www.mediafire.com/?jvm2emzfyhm
    SK-Tools:key http://www.mediafire.com/?wnywy5z4dvt
    SKTools 4.4.4-WM5-6-VGA. http://www.mediafire.com/?ddigzmnmnmm
  8. Các thành viên gửi lời cám ơn tới bài viết:
    baby heo (13-11-2008), eternal_faithful (28-11-2008), N123456 (11-11-2008), sgking21 (04-11-2008), vinhyen (04-11-2008)
  9. #1805
    Ngày tham gia
    Dec 2004
    Đến từ
    Bài viết
    3,869
    Thanks
    492
    Inesoft Phone v4.0 Final
    [Adt">
    N*RD*"' 1R
    Address Book is the best contact manager with Additional Phones and Fields, Instant Search, Ring Tones, Photo Caller ID and Phone Profiles. k b .M%4
    Inesoft Address Book - the most convenient way to manage contacts on Windows Mobile device. L"wzHUMr
    Fr-k[Og"
    Inesoft Phone 4 is especially designed to expand "phone features" for Windows Mobile devices. The software combines 6 main applications in one making the phone usage easier. Inesoft Phone includes: Dialer, Caller ID, SMS and Calls History, Favorite numbers, Profiler and Contacts. g}FfG/SWR
    7MpjHZU_
    Link:
    http://www.uploadjockey.com/download/nc267tm0/Inesoft.Phone.v4.0.Build.2008.11.01.CAB %`-dq22D-
    http://rapidshare.com/files/159686735/Inesoft.Phone.v4.0.Build.2008.11.01.CAB F-$S&5uq
    http://www.megaupload.com/?d=MD9J3UXA |+n)SW).l]
  10. Thành viên gửi lời cám ơn tới bài viết này:
  11. #1806
    Ngày tham gia
    Dec 2004
    Đến từ
    Bài viết
    3,869
    Thanks
    492
    iContact Burt Edition 6.4.5
    iContact Burt Edition (iContact BE) is a separate branch of iContact application, finger-friendly contact manager, which was originally started by Larna and expanded by supbro. iContact BE came apart of supbro's iContact since version 0.73, and is not related to any supbro's versions later than 0.73. `tMkN+z\
    ci.+q08:
    Thanks to larna and supbro for creating and developing such a great application! W[z%HL5N
    ,4 \7GPG
    Latest Beta Version: October, 31: iContactBE 6.4.5 beta wG2^qf }
    uVUqSy= m
    Downloads: Sc ( &v]
    The latest stable release is 6.4.5, attached to this post and available on my home page 0 7L_3&!
    St?dQ6v.O
    iContact Burt Edition 6.3 at Touch-Innovations.com Le&'@]"
    1{/4iuV
    Application Files and Skins can also be found at my SkyDrive workspace: iContact Burt Edition at SkyDrive Fj pR1@Ud
    Skins: RrpnZ6
    Skins for iContact Burt Edition 6.x ja4E2
    gOSov4
    Skinning tutorial, including the .skn file options and .png file layout, is available at my home page. F xb
    Requirements: W]"+pF
    Windows Mobile 5.0 or higher 1S*eee
    Phone device ,0 ;mTN|v
    Thanks everyone who helped with beta-testing, I couldn't get so far with iContact without you! P5m?+7e
    `zcNP;+
    Since I've been asked for a donation link, you can do a donation here (WebMoney only, since PayPal donations do not work for Russia). 1{m!\A
    l:sAXAH
    Main features: l2OUD,v
    It's totally free 3O~N[iD
    Finger-friendly contact management 0 Wf_Ry_
    Contact pictures support C,=!n).
    Integrated Call History bJ 9[m
    Favorite Contacts list V7|VbPf5=
    Quick jump to contacts by alphabet letters _=%eWw5,]S
    Filter contacts by categories ^2b[%A%
    Fast and comfortable work even on slow devices, loading time is less than 1.5 seconds for 100 contacts on 200MHz devices r-BaJPWo
    Optional SIM contacts support eaom@@{=_
    Full-scale T9 search kz?kL%O-
    Ability to Call, SMS or E-Mail to a contact 4f<7Ne
    Handy contact details screen A! gZmbs
    Quick access to standard Outlook's contact viewing or editing dialog xMJFo5W
    VGA support qI+{
    Fully skinnable interface. Two QVGA skins included, more skins can be found in my Skin Downloads area or at forum.xda-developers.com vaOm>ie8
    Changes since 6.4: $96`EfX L
    - Fixed drawing of default number in Contact Details (indicator icon placement fixed, DetailsDefaultNumber color used) <vx}4_f1s
    - Fixed bug with going to Contact Details from Call Details when call history pictures are disabled (also fixes bug where button 'create contact' was still accessible after creating contact from call details) 3^Uggd2Pm
    - Fixed bug with call not shown in Call History if Get Call History From Database is off and only one call exists in the log 3WJQss:t#n
    - Fixed list update on adding/removing categories through Outlook Edit Contact window 3P3 %~Ps
    - Fixed Exit On Action option )A17'*)
    Main changes since 6.3.1: q%H$=C
    - Huge memory leak bug fixed Vn n:a?%
    - iDialer support, added command-line parameters for iDialer (-favorites, -recents, -contacts, -dialer, -search) #`L~`%0
    - T9 keyboard polished <sg7Ma1m
    - Now it is possible to search by beginnings of words ('T9 Search By Words' option), e.g. 'smi' will find both 'Smith John' and 'John Smith', but not 'Dart Cosmic' eZEo}d&,e
    - Other Address and Anniversary added to contact details @<$H6DnO
    - Long tap on Dialer button calls default dialer, short tap calls dialer from settings, if given go,ud/0a
    - Phone Prefix option now available, allowing to add a prefix to all dialed numbers hVzOzut[Y
    - If an external SMS/Mail/Dialer application can not be run, then default app will be called <$H6wf*
    - Repeats in Call History are now handled properly Khn5%6
    - Smart Dialing Number is now OFF by default to avoid ActiveSync synchronization issues U1jfQ~1
    - Smartphone users can now access bottom menu in Details by pressing corresponding numeric key (1 for Back, 2 for View Contact, etc) gYq><V
    - Back key now erases last char in search string on Smartphones 7{qhaTc
    - Background in Details is now drawn gradient for long details too wL(huI{
    - Configurator updated to 1.15, now can restart iContact on settings change ]*yMH &n
    - AppToDate support =D`OUO3/=
    - No skin changes, you can use the skins from previous release Q;N)Rx:+.
    '#R!=_cE
    http://burt.vndv.com/ ~\]X!cVSr
    wPs_);\
    Download: ,Ko`^X
    http://burt.vndv.com/index.php?ind=downloads&op=download_file&ide=54&fi le=iContactBE6.4.5exeOct31.zip
  12. Các thành viên gửi lời cám ơn tới bài viết:
    eternal_faithful (28-11-2008), vinhyen (04-11-2008)
  13. #1807
    Ngày tham gia
    Dec 2004
    Đến từ
    Bài viết
    3,869
    Thanks
    492
    Diamond TV 2.1-Latest version is 2.1 (29 Oct. 2008)
    Phần mềm xem TV trực tuyến thông qua các kết nối mạng(WIFI/EDGE/3G...)với hơn 300 kênh truyền hình quốc tế,trong đó có 2 kênh của Việt nam.Phần mềm hỗ trợ tiếng Việt không dấu,chạy trơn tru với Windows Media Player đặt ở
    chế độ WIFI/Lan 1.0Mbps với kết nối WIFI.
    Link: http://www.mediafire.com/?mfltiyqzjza
    Nếu như k đăng ký được bạn có thể dùng:
    Name - Gio
    Key - VTWKG-C49SE-Z6NQB-3PFM1-AIL5K
    (dùng phần mềm multi owner để đổi owner)
  14. Thành viên gửi lời cám ơn tới bài viết này:
  15. #1808
    Ngày tham gia
    Dec 2004
    Đến từ
    Bài viết
    3,869
    Thanks
    492
    Trích dẫn Từ bài viết của baotrung1305 Xem bài
    Giới thiệu: IM+ All-in-One Mobile Messenger v. 5.36
    Phần mềm chát nổi tiếng trên PPC cập nhật phiên bản mới
    Bản Full sẽ cập nhật sau.
    FULL: http://www.mediafire.com/?xigzngwdzm5
  16. Các thành viên gửi lời cám ơn tới bài viết:
    jerrylouis (03-11-2008), tneo (20-11-2008)
  17. #1809
    Ngày tham gia
    Dec 2004
    Đến từ
    Bài viết
    3,869
    Thanks
    492
    iWeather v0.1
    First release
    this is the first release of my first own app for a pocketpc. It's completely written in VC# and should work on all devices up from WM5 with QVGA screen. I'm a totaly noob in writing or coding apps, but maybe you like it.
    The app uses the weather feed from yahoo (or weather.com). When you run iWeather, you need to connect to the internet. Same for the Settings.exe.
    How to:
    1. open Settings.exe
    2. enter your LocationID
    3. press ENTER
    4. press Done-Button
    IMPORTANT! It is nessessary to stay online!
    Things to do
    - fix battery-bug in Settings.exe
    - adding more than one location
    - open settings by pushing the "i"-button
    - caching data for offline use
    - maybe integrating settings into iWeather
    - maybe different language support
    v0.1
    - first release
    - only one city-weather is possible
    - search in Settings.exe only writes the LocationID (e.g. USNY0996) and the displayed unit into the city.xml (you can find your LocationID at http://weather.yahoo.com )
    - Settings.exe gives as validation the city-name to the entered LocationID.
    - it's not possible to start settings from iWeather
    - iWeather will automaticaly start, after pushing "done"-button in Settings.
    - background-image and icons will change after sunset or sunrise of the selected location
    - both apps can be closed by pushing the battery on the upper right corner
    Link: http://www.mediafire.com/?gqw3yzof0yz
  18. Thành viên gửi lời cám ơn tới bài viết này:
  19. #1810
    Ngày tham gia
    Dec 2004
    Đến từ
    Bài viết
    3,869
    Thanks
    492
    VZOchat Mobile v1.1 beta
    This is a free program to an international interactive video communication. The program specifically written for communicators based on Microsoft Windows Mobile 5.0, 6.0 and 6.1. The program is optimized to work at low internet channels.
    Using VZOchat mobile, you can:
    - Call on video at each other Communicator, you pay for toleo Internet connection;
    - Contact on video with a friend who has a computer;
    - If there are no cameras - no trouble, talk to other voices;
    - In case of urgent need, your friend will be able to record video, taken from you!
    At the office. the site has a version for PCs.
    More info
    http://www.vzochat.com/en/Default.aspx
    Link: http://www.mediafire.com/?myoznjtenja
  20. Thành viên gửi lời cám ơn tới bài viết này:
Chủ đề đã khóa
Tags cho chủ đề
Bookmarks
Quyền hạn
  • Bạn không thể tạo chủ đề mới
  • Bạn không thể trả lời bài viết
  • Bạn không thể gửi file đính kèm
  • Bạn không thể chỉnh sửa bài viết của mình
[Output: 132.20 Kb. compressed to 122.03 Kb. by saving 10.16 Kb. (7.69%)]
