eternal_faithful (28-11-2008)
Pocket PC Media Manager 1.3
Pocket PC Media Manager description ,)%( :Ie
OrS~LOj0zc
Pocket PC Media Manager allows you to remotely control your computer's Media Player via SMS. NRY n+
Pocket PC Media Manager is a remote control for your computer's Media Player. You run this simple program on your Pocket PC and you are able to switch songs, pause/play, and stop music from anywhere in the world through SMS. You of course must be running a program on the computer as well. Both programs are included, the PC part uses AIM to receive SMS messages so you will have to sign up for a screen name for your media manager at AIM.com, but that is a quick and simple process and then everything goes smoothly. It sucks very little battery life and you don't need wireless or an internet plan, it also allows your computer to run the software from behind a firewall. The other programs that do this require you be outside your firewall running a server program and that your Pocket PC be connected to the internet which sucks battery life like no other. You do have to watch out for sending too many messages or AIM will ignore them for a second. And be patient! One button per couple of seconds PLEASE!
Link: http://www.mediafire.com/?ed9w0jjl0ua
Ifonz 1.1.2
Phần mềm quen thuộc , vuốt và trượt như iphone
Link:
QVGA: http://www.mediafire.com/?j1wdperm2u8
VGA: http://www.mediafire.com/?uyxeijnbcx9
Avira GmbH AntiVir Mobile v6.41.0.1 & *=QZw8
Requirements: Pocket PC 2002, Windows Mobile 2003 for Pocket PC, Windows Mobile 2003 Second Edition, Windows Mobile 5.0, WM6 k2J cY"5
Overview: Professional virus and malware defense for Pocket PCs and smartphones _ze['CI
T%*5]]7P
Descriptions: 30NH 7'Ete
Simple installation and updates within seconds: C<\E{
* Transmission of the program package by docking onto the local PC (PDA) or via Bluetooth, IrDA, GPRS or δεrial cable (smartphone). o" 5 za'T$
* Automatic installation of the English or German version ?“ depending on the language set (smartphone). F IO2@
* Simple manual program update via LAN, WLAN or dial-up (PDA) or via Bluetooth, GPRS/GPS or WLAN (smartphone). Update also possible via host PC. p3}n]F)V
* Roll-back in case an update could not be carried out completely. [57t%U1[
* Automatic scan-on-sync protection (PDA) for secure data synchronization x'A 7c
Individual setting possibilities and transparent status information: 1r^]N@N
* Clear menu navigation that does not set any riddles. g#0y_m!
* Flexibility through definition of the scanning scope. h$<VVSb Q@
* Optional scanning of ROM files and/or cards and network folders .<|-6)#
* Automatic or interactive procedure in the event of a virus detection). r J_6*{y
* Possibility to delete infected files. %gg77@
* Specific information on every virus detection, so that you are always in the picture. Version information can be requested at any time J,]#)(15
More Info: Z5, 'Iv
Code: (%AKo_
http://www.avira.com/en/products/avira_antivir_mobile.html ph=k0V' Fu
Download Instructions: DNIq]q(M
http://rapidshare.com/files/91496141...icense.key.rar c;Q0cB
Copy the k3y file to the root of your SD card, activate using it & enjoy the full version
Adisasta wmZip v3.1.3 Build.3130.XScale.WM5.WM6 F+CJ"o
WinMobile Zip v.3.1.3 is a multipurpose encrypting and archiving tool. WinMobile Zip enables you to effectively store and secure your sensitive data in a single operation. It supports AES for the state-of-the art encryption technology in a popular zip archive format. J:p-a '
qpoO|ZP
WinMobile Zip features user friendly multi-tab interface allowing intuitive single-handed operation using softkeys and hardware navigation buttons. WinMobile Zip has a dual-folder design that enables user to copy, move, extract or compress files from one folder to another. WinMobile Zip also supports viewing and extracting of a wide range of archive formats such as ISO, CAB, ARJ, LZH, Z, DEB, CPIO, TAR, RAR, BZIP2, CHM, RPM and SIS. HNjfe>PzOt
Download: Zk)w`\W4W
http://rapidshare.com/files/11340324...nly-SyMPDA.rar
http://tinyurl.com/5spw95
Description:
vQm.bW3y
With this free tool you can "read" into the future, as well as your past. / Egd 29
Ever wondered what impact your birthdate and birthtime have on your life and existence? Ever wondered when is the best time to start a project? The best time to get married? !d#) U()$
`1;8Wuuc
With this free tool you can "read" into the future as well as your past. DM4PChart allows you to plot your 4 Pillars ( or Bazi ) for free on your Pocket PC. This tool allows you to plot from year 1912 to 2049. M.'!5[$#P
%@~H
B".A[Z
What's New in This Release: [ read full changelog ] FBNCB7G3~
a/PM8e
· Fixed the bug where Hidden Element Images are not cleared when generating 2nd chart onwards l zalM/5
FLE !u}S
http://destinylogix.googlepages.com/ "iyQ`OfO
M#{qi"rM
Download: uAS87vYu0
http://destinylogix.googlepages.com/DM4PChartv1.01InstallationPocketPC.zip
Description:
`c73zpu
McAfee Mobile Anti-Theft provides protection and safety from theft or loss of your mobile device and helps you retrieve it. &8] 3O%
McAfee Mobile Anti-Theft provides protection and safety from theft or loss of your mobile device and helps you retrieve it. The software runs on your cell phone and verifies its security status every time the phone is started. This is done via identifying and authorizing one or multiple SIM cards that can be used in your phone. When an unknown SIM card is inserted, McAfee locks all of the phone's functions making it useless to the person who stole or found it. A> JjR9(
%=}i
McAfee Mobile Anti-Theft will also report this security breach immediately via SMS text message to an alternative phone number you selected. This text message alert will include the finder's/thief's contact number and the network celll your phone is currently connected to. You can then use free cell-to-map web services to locate your device or share this information with law enforcement and insurance claims officials. B )L]
sbg - VG
O5a U{p
Download: q.<VXMZ9"
http://download.mcafee.com/products/mobile/matw/McAfee%20Mobile%20Anti-Theft.CAB
eternal_faithful (28-11-2008), hson (31-10-2008)
SpaceTime v3.0 Update 9-2 hk7J.}$!N<z`318yKA
Requirements: Windows Mobile 2002/2003/2003SE/5/6 (iTL,(
fMe=5:z
Overview: SpaceTime 3.0 by SpaceTime Mathematics is a revolution in mathematics software with 2D, 3D, and 4D graphing with MobileCAS® Technology for computer algebra and calculus. Explore mathematical concepts in an innovative interface with interactive tutorials that teach you how to plot graphs, solve equations, and write your own scripts in our new powerful programming language. R/h-ZO
V]G5xn\
WK+;.N:*
From the high school student to the professional engineer, SpaceTime 3.0 allows you to explore mathematical concepts in an easy-to-use interface with helpful tutorials that show you how to plot graphs, calculate equations, and solve formulas in seconds. SpaceTime turns monochrome math into full color, real-time art. @.2=N
zZW
New functions in Update 9! PH^RD<>E~
* Insert "n2|D)
* Delete B%-R/zGJ
* Extract 7)x ?$W1
* String wJ=?Q8%X*
* Date UeR$_ 8b=_
* Value J\ ^1*w2H0
* cFrac JpP1?]Nw>
* Convergents X;; u_l
* AlternatingSeries fe1cPv6}
* Pi_Digits /4s'Gm
* PolyGCD dkA6w&a!!$
* PolyLCM ! ]p Y9z
* LambertW .dbY|C^C
dbnHqrV%
Download Instructions: B/g;SN<ne
http://www.uploadjockey.com/download/7305150/spacetime.v3.0.update.9-2.cr_cked-runliu.cab ! cKPgFA
Z rJw]Nd
Mirror: ]Skgm/ q
http://rapidshare.com/files/154425149/SpaceTime.v3.0.Update.9-2.Cr_cked-rUnLiu.CAB gmSp^ g
http://www.megaupload.com/?d=YJFMEBB9 [Cg
eternal_faithful (28-11-2008), frog96 (26-10-2008)
ActiveKitten Chronos v3.9.6.3 4Xc<ztT|Inh$ul4e<
Requirements: Any Pocket PC WM2003-WM2006 with ARM/Xscale processor QR$ O{9/
Overview: Chronos fills a gap in PocketPC operating systems by offering an unlimited number of alarms and timers with customizable sound (MP3, WMA and OGG) and time settings. Two countdowns with lap times lets you track time spent on certain tasks. Supports VGA, square screens and landscape orientation. 4~=6tm D'
hHF= m?
T}}Vs
_}'KT 2D
1. Unlimited number of highly customizable alarms: b,oLq~Rd@
* Alarms can be set to signal only on certain days of the week; c>7xQ@7X
* alarms can be one-time or repetitive; vv879@^.
* alarm can notify you by playing sounds, turning on/off vibration, blinking the LED; m0:QZ'ML
* WAV, OGG, WMA and MP3 alarm files are completely supported as sound notification; 8J'Os@>4f
* you can select custom sound stored in memory or on the storage card; F`}`z W)~
* the sound can be played with ascending volume and in loops (i.e. as many times as you need); FOeK2| =iF
* vibration (requires hardware availability of the feature) can be set to work before or with the sound. Pulsation is customizable too. ;X!gq:c
2. Unlimited number of countdown timers. These timers are used to notify you when certain amount of time elapses. You can completely customize sound and vibro notifications for the timer (in the same way as for alarm). Settings of each countdown timer can be saved as a template for future use. You can build a sequence of timers. chB2a)V
3. 2 multi-stage timers that let you count time of some action and compare results of two attempts. You can use timer to fix intermediate results (for example when you run 5 laps, you can track time of each lap). f m'|6
4. Skinnable clock with screensaver and hourly sound lets you have better control over your time. zz!E<6P
7w/W*Gif
What's new in Chronos for Pocket PC 3.9.6.3: >S$Uxv
· Fixed audio quality p%K VO$
· Improved responsiveness of stopwatch buttons Sa _<-
· Added support of vibration to Samsung i900 PDA Eaaxuoi
EZ\*h,r0A
Download Instructions: 4XUX&
http://www.uploadjockey.com/download/9596579/activekitten.chronos.v3.9.6.3.cr_cked-runliu.cab X7ahsRv
YHMjnxW
Mirror: h`6r
http://rapidshare.com/files/154421784/ActiveKitten.Chronos.v3.9.6.3.Cr_cked-rUnLiu.caB ^+ nZ~Yo
http://www.megaupload.com/?d=41Q4ZP1R
TASK FACADE v0.6.b1
c-lRVF/<#N
:~i{8EX~3
Graphical task-switcher that shows all running programs as snapshots (Vista-style). VUHNUK|gp
Runs on any WM version and any resolutions. ]ABwNnMG^
<QP^*a.ae
0.6.b1 /2008-10-15/: \tJ' k\' *
# fix: no more collisions because of multiple instances of Facade $~=sqb|mH
# fix: properly installs/deinstalls in the card memory ZEd\RpbWi
+ new: 2x3 orientation: horizontal or vertical (see config.txt, horizontal alignment setting) }s[W0KYjfj
mo5J`5|z
*uNQAZ RYm
Download: http://www.freewarepocketpc.net/ppc-...sk-facade.html
eternal_faithful (28-11-2008), ngquangbien (18-10-2008)
G-Alarm 0.8.6 (2008/10/15)
G-Alarm 0.8.6 (2008/10/15) /$ $n'
A list with some features: 13NWs vN
Supported devices: all devices with Windows Mobile 5, Windows Mobile 6 and Windows Mobile 6.1 J K6QWK
Supported languages: ? ? ? ? ? ? ? ? R':Xm,j
Skinnable user interface (Lots of skins are available here) *9,nuN"
Customizable today plugin which shows you all your alarms and lets you activate or deactivate them with one click E.8i1D7mI+
Define unlimited alarms with many options 'j+ LYT
Choose between different alarm types mk} 5i7
Weekdays: select on which days of the week an alarm should go off |Nl}ldL
One-time alarm Kp1z9,
Alarm patterns: you can define more customized alarms (e.g. play the alarm every 4th week on friday at 7:00 PM) j!e1^+d
Define playlists with unlimited mp3/wma/wav files for each alarm ;pvt;$8ou
Force a specific volume if the device is on vibration mode or muted s{paW
Repeat and playing options: V+:0yr
Play alarm for a specific time '.N&\_
Repeat an alarm for x times Fd4LD=u
Auto-snooze the alarm after a specifc time Ht|pH}Sm
Supports all resolutions (VGA, QVGA, WVGA, WQVGA, etc.) LUuT?;DTE
Power saving methods: ikz|/"|O
You can set to turn off the display after a specific time so you can listen to your music while the device doesn't eat too much battery 9cET\G9w
The display is turned off if the alarm snoozes .r{azj
Tilt sensor support (only on supported devices) tm3 cm A
Guide the ball through the maze by tilting your device ydJ s6s
Snooze the alarm by turning the phone upside down YBq1@3}F
Light sensor support (only on supported devices) Zp+2Q$o
Snooze the alarm by turning the light on 0|cr,(/vt
You can decide wether you want to complete mazes before you can snooze or stop the alarm or not. u9fSk-D|n
See your next alarm in S2U2, TouchFlo3D, Manila2D and others Y"s Y}
After you have completed the maze you can snooze or close the alarm \Dia6e7O6/
G-Alarm Changelog ^J-|5kp
0.8.6 (2008/10/15) y=hv8``.U
[ADDED] The alarm is now shown over the PIN lock window and probably over all other applications Mpo,g
[ADDED] Context menu when tapping and holding on the snooze button $2[?SLA
[ADDED] hidden option: Don't wakeup at midnight 1:+< ]
[UPDATED] Default skin c%t&H%6p
[UPDATED] Language: czech, korean pou](B`
Download skins for G-Alarm dx"B2u
http://www.ageye.de/index.php?s=galarm/skins r,kVaI 1
Download:
http://www.ageye.de/download/galarm.cab
Bookmarks
