baotrung1973 (03-09-2008), daylight (15-08-2008), g_phuonganh (15-08-2008), haoatvb (18-08-2008), Mr.BRAVO (08-09-2008), s4ever (29-09-2008), thaiviet0000 (24-09-2008), xppro (04-09-2008)
Spb Mobile Shell v2.1.2 Final
* Option to show all day events
* Option to hide "free" events
* Fixed compatibiblity issues with some custom skins
* Fixed Palm Treo 800w compatibility issues
* Reduced sensivity of closing gestures
* Other minor bug fixes
Download: http://www.mediafire.com/download.php?hcn9vfzwv0n
Thuốc thang cho nó ở đây: http://www.mediafire.com/download.php?i3hs1xjeqoy
Lonely Cat Games ProfiMail v2.91
(F.u.l.l)
ProfiMail for Pocket PC description:
ProfiMail is application for your everyday life. It is a communication solution for your mobile device. Wherever you go, you have your e-mail with you. With program?s user interface, you can see a great part of message on screen at a time, and easily navigate during reading.
You can use ProfiMail for your professional work ? reading documents sent in messages, comfortably answer to sender, or send documents from device.
You can also use ProfiMail for being in touch with your friends, who use e-mail on a desktop computer. For example, you can send photos taken with phone camera immediately.
The program was designed to be as simple as possible, while offering very easy controlling, and many useful functions, essential for comfortable work with your e-mail.
From now on, don''t be tied to your desktop PC. Simply have e-mail always available to you anywhere you go.
Here are some key features of "ProfiMail for Pocket PC":
· Automatic synchronization of messages with mail server
· IMAP folders
· Attachments - view, save, send
· HTML messages with images and hyperlinks
· Built-in File Explorer
· Address book
· Signatures
· Writing mails using T9 dictionary
· Support for POP3 / IMAP / SMTP mail servers
· Multiple email accounts
· Rules and filters allowing selective message download
· Opens and browses ZIP archives
· Support for various character encoding - Western, Cyrillic, Central European, and more
· Build-in image viewer - JPG, PNG and other popular formats
· Text viewer for standard text, HTML and Word documents
· Optimized for GPRS - get headers first, then download message bodies which you really want to see
What's new in this release:
· Improved license checking, detecting silent ringing type, simple audio player, Chinese language
Requirements:
· Windows Mobile 2003/5/6
Link :
http://www.uploadjockey.com/download...mail.v2.91.rar
http://www.ziddu.com/download/1918899/Profimail.v2.91.rar.html
Chú ý : Đăng ký với số bất kỳ
ok để mình thử lại tại mình giải nén ra double click vào mà nó báo lỗi không.cám ơn bro nhiều
Click Thanks những bài post bạn cho là hữu ích:hug:
VITO Technology Sound Editor 1.4.4
Phần mềm hỗ trợ cắt các bản nhạc, bài hát có định dạng .WAV để làm nhạc chuông.
Link: http://www.mediafire.com/download.php?ehnb4je0khq
Hướng dẫn sử dụng: http://vitotechnology.com/manual/soundeditor/
eternal_faithful (05-09-2008), haoatvb (18-08-2008)
Resco Media Suite v6.55
Phần mềm đóng gói của Resco bao gồm:
Photo Viewer 2007
Audio Recorder
Pocket Radio
Explorer 2008
Download: http://www.mediafire.com/download.php?z0urrnkiz7q
Resco Explorer 2008 for Pocket PC (v7.04) phiên bản cập nhật ngày 18/8/2008
Download: http://resco.net/pocketpc/explorer/downloads.asp
Đây là bản update nên vẫn dùng k.e.y cũ nhé.
Hướng dẫn sử dụng: http://resco.net/Documents/Explorer_help.pdf
Hướng dẫn chỉnh skin: http://resco.net/documents/Explorer_Skin_Spec.pdf
Resco Utility Package (v6.55)
Phần mềm đóng gói utilities bao gồm:
- Photo Viewer 2007
- Explorer 2008
- Keyboard Pro
Download: http://www.resco.net/pocketpc/utilpack/default.asp
K.e.y: http://www.mediafire.com/download.php?5rl9o4qzljf
eternal_faithful (20-08-2008), laophuong (29-08-2008)
Pocket Digital Clock Version 1.1.8 (3 August 2008)
Pocket Digital Clock (PDC) is a small and simple program that shows a large digital clock with optional seconds display on the Windows Mobile Today Screen. Date is shown above the digital clock very much like the HTC Home plug-in. ) w
Features:Orientation awareness
Large digital clock with optional seconds display
Light-weight program
Portrait/landscape and square screen support
96, 128 and 192 DPI support
Low CPU usage
TrueType (non-bitmap) font rendering
Optional network operator name display
Customizable
Freeware
Requirements:
- Windows Mobile 5.0 or newer (Pocket PC only)
- Microsoft ActiveSync or Windows Mobile Device Center (for installation)
Download: http://project.ionized.googlepages.com/downloads
Bookmarks
