+ Trả lời chủ đề
Trang thứ 3 trong số 5 Đầu tiênĐầu tiên 1 2 3 4 5 Cuối cùngCuối cùng
Hiển thị kết quả 21 đến 30 trên tổng số 44
Chủ đề: Voyager Home Screen Tuỳ biến giao diện màn hình chờ
  1. #21
    Respected member tichau's Avatar
    Ngày tham gia
    Oct 2006
    Tuổi
    34
    Bài viết
    10,791
    Thanks
    1,252
    Voyager Home Screen v3.23b [EN] S60 3rd Unsigned Freeware
    Voyager Home Screen(vHome) is a FREE ware helps you customize your S60's home screen with big clock, start menu, weather, news ticker,Google,fav contact,smart dialing ,etc.
    Features:
    Features like Google, weather, news , Operator logo, big clock are pretty straight forward, if you do not like a certain feature, just press C to disable it.press left/right on to-do bar and news bar could switch item.
    Quick task switch: we use the red end key to switch between running tasks,it's lot easier than pressing home key and then select, also you will never quit java apps like Opera Mini/Gmail by accidentally pressing red key.
    Smart dialing: just type one number for one letter , to find any contact fast.Like 2455 for Bill. You can use this for apps,too. Like 46245 for Gmail. You might find phone's menu a bit useless when you can get to anything from home screen with smart dialing.
    Start menu: another way to organize your apps, you can locate an app using smart dialing, and place the app in start menu or home screen shortcut easily. And we support sub-folder in start menu.
    MyFav: we scan your call logs automatically. and place the people you call/text most frequently in MyFav feature, on the home screen's right selection key.(of course you can change this with any app you want).press left/right key in this, you can see your most used apps,too.
    vApps: yeah, we include a mini app store , the seventh shortcut. not too many apps for now(tell us what you want to see here), we want to gather the best free apps here, all fit your phone model(we test and organize them by screen resolution, mr/fp1/fp2 etc, so you don't have to).just one click to download, auto install to E: , dead simple.(the list is updated automatically , so check in once in a while).
    New app popup: after a new app is installed, you would see a popup asking if you would like to run it now. save you time digging in to menu to find it.
    Web directory: Click web browser, you'll see our directory page. all most popular mobile sites(hopefully). If you don't like it, just turn it off in Start-Settings-More
    Keypad Lock: sorry the system's settings would not work, please setup again in vHome.Lock is easy: Start-Lock, much better than old way. Press end key twice to unlock.
    Connection: by default,vHome update weather/news each hour, 9:00-23:00 (no update if you disable news and weather), change this in Start-Settings-Connection to suit your needs.
    Updates:
    1. bug fix: when using app(not on vHome), you get an incoming call, and you can not hung up
    2. bug fix: Operator Logo becomes big after using MyFav feature
    Nước biển mênh mông không đong đầy tình mẹ.
  2. Thành viên gửi lời cám ơn tới bài viết này:
    nnq2784 (13-06-2010)
  3. #22
    Senior Member anxongjong's Avatar
    Ngày tham gia
    Feb 2006
    Bài viết
    218
    Thanks
    36
    Cái lỗi này vẫn chưa fix được. Không dùng nút đỏ để ngắt cuộc gọi được, chỉ có nước chờ đầu dây bên kia...gác máy dùm, nếu bấm sai số thì hơi bị...mệt. Còn khi từ menu chính thoát ra thì lại vào màn hình standby chứ không phải màn hình vhome.
  4. #23
    Super Moderator minhtue's Avatar
    Ngày tham gia
    Aug 2005
    Bài viết
    2,930
    Thanks
    192
    Voyager Home Screen v3.31b S60v3 SymbianOS9.x Official Signed EN
    Last update: 07/02/2010
    Features:
    Updates:
    1. home screen music bar update: mr and Samsung models do not show;
    for fp1 models,click music bar switch to music player; for fp2 models, click music bar to play/pause. some fp1 models like 5700,6120, can not use left/right to switch songs. this is a Nokia issue, we can not make it work now.
    2. news feed transcoder switched to Google gwt
    3. autostart should work now
    4. now support 4 music keys on N81's music player
    Signed Version Note :
    no more bugs fixed. I think we might need to sign a new version each
    2-4 weeks in the future, in other words, much faster than current
    development pace, and a good FAQ is needed.
    Tôi rất sẵn lòng chia sẻ mọi thứ tôi có thể và tôi hạnh phúc vì điều đó!
  5. Các thành viên gửi lời cám ơn tới bài viết:
    boypluto (01-05-2010), darkdemon85 (18-02-2010), hth2813 (09-02-2010), huyhaptnvn (13-02-2010), krAGO (13-06-2010), nnq2784 (13-06-2010), tdvcb44 (18-06-2010)
  6. #24
    Moderator verylove's Avatar
    Ngày tham gia
    Feb 2006
    Đến từ
    Tuy Hoà - Phú Yên
    Tuổi
    Bài viết
    3,383
    Thanks
    870
    Voyager Home Screen (vHome) v3.33 [CN] S60v3 Signed Freeware [Update: 15.03.10]
    Voyager Home Screen (vHome) is a free ware helps you customize your S60's home screen with big clock, start menu, weather, news ticker, Google, fav contact, smart dialing, etc.
    Key features:
    Features like Google, weather, news, Operator logo, big clock are pretty straight forward, if you do not like a certain feature, just press C to disable it. Press left/right on to-do bar and news bar could switch item.
    Quick task switch: we use the red end key to switch between running tasks, it's lot easier than pressing home key and then select, also you will never quit java apps like Opera Mini/Gmail by accidentally pressing Red key.
    Smart dialing: just type one number for one letter, to find any contact fast. Like 2455 for Bill. You can use this for apps, too. Like 46245 for Gmail. You might find phone's menu a bit useless when you can get to anything from home screen with smart dialing.
    MyFav: we scan your call logs automatically and place the people you call/text most frequently in MyFav feature, on the home screen's right selection key (of course you can change this with any app you want). Press left/right key in this, you can see your most used apps, too.
    vApps: yeah, we include a mini App store, the seventh shortcut. Not too many apps for now (tell us what you want to see here), we want to gather the best free apps here, all fit your phone model (we test and organize them by screen resolution, MR/FP1/FP2 etc., so you don't have to). Just one click to download, auto install to E:, dead simple. (the list is updated automatically, so check in once in a while).
    New app popup: after a new app is installed, you would see a popup asking if you would like to run it now. Save you time digging in to menu to find it.
    Web directory: Click web browser, you'll see our directory page. All most popular mobile sites (hopefully). If you don't like it, just turn it off in Start-Settings-More
    Keypad Lock: sorry the system's settings would not work, please setup again in vHome. Lock is easy: Start-Lock, much better than old way. Press end key twice to unlock.
    Connection: by default, vHome update weather/news each hour, 9:00-23:00 (no update if you disable news and weather), change this in Start-Settings-Connection to suit your needs.
    NOTE: Changelog not available!
  7. Thành viên gửi lời cám ơn tới bài viết này:
  8. #25
    Advance Member hth2813's Avatar
    Ngày tham gia
    Oct 2009
    Tuổi
    19
    Bài viết
    80
    Thanks
    44
    Voyager Home Screen v3.53b [CN] S60v3 SymbianOS 9.x Signed
    Key features:
    Keypad Lock: the system's settings would not work, please setup again in vHome.
    What's new:
    Added new server for faster downloads weather reports and news feed. Reduced consumption of traffic.
    ● Upgraded weather information source, weather reports now more stable and accurate.
    ● Updated Task Manager for the E-series models, for other models Task Manager is disabled by default.
    ● Added templates for redesign "Big clock" option. Currently it supports only for model with vertically oriented screen. N71 and others aren't supported.
    ● Solved problem with wallpaper when using Nokia classic mode.
    ● Solved Two-Desktop mode switching error.
    ● Fixed bug for Nokia N72.
    ● Changed default settings for download news feeds.
    Code:
    http://www.mediafire.com/?ly2z00t2dqy
  9. #26
    Ngày tham gia
    Feb 2006
    Đến từ
    Tuy Hoà - Phú Yên
    Tuổi
    Bài viết
    3,383
    Thanks
    870
    Voyager Home Screen v3.55b [CN] S60v3 SymbianOS 9.x Unsigned
    Key features:
    What's new:
    No Change Log available!
  10. #27
    Expert Member manbk401's Avatar
    Ngày tham gia
    Aug 2008
    Đến từ
    Đông Anh - Hà Nội
    Bài viết
    439
    Thanks
    162
    Voyager Home Screen v3.62d [CN] S60v3 SymbianOS 9.x Unsigned
    Key features:
    What's new:
    DO YOUR BEST - SOMETHING ONLY WE CAN DO
  11. Thành viên gửi lời cám ơn tới bài viết này:
    peter 1 (25-04-2010)
  12. #28
    Ngày tham gia
    Feb 2006
    Đến từ
    Tuy Hoà - Phú Yên
    Tuổi
    Bài viết
    3,383
    Thanks
    870
    Voyager Home Screen (vHome) v3.63c S60v3 SymbianOS 9.x Signed [Update: 30.04.10]
    Key features:
    Keypad Lock: the system's settings would not work, please setup again in vHome. Lock is easy: Start-Lock, much better than old way. Press end key twice to unlock.
    What's new:
    Switching-off of the manager of system
    Adjustments of the red button (function)
    Adjustments for a standard desktop
    And other changes
  13. #29
    Ngày tham gia
    Feb 2006
    Đến từ
    Tuy Hoà - Phú Yên
    Tuổi
    Bài viết
    3,383
    Thanks
    870
    Voyager Home Screen (vHome) v3.71 S60v3 SymbianOS9.x Signed Chinese (Upd:31.05.10)
    Features:
    Change Log :
    Change log not available
  14. #30
    Senior Member mabu's Avatar
    Ngày tham gia
    Feb 2005
    Tuổi
    33
    Bài viết
    138
    Thanks
    33
    Các bro cho hỏi, tui đang dùng bản 363c, trước đây xài E72 FW cũ thì cái plg weather chạy tốt, từ hồi nâng cấp FW thì nó không hoạt động được nữa (ko tìm ra được bất cứ location nào mặc dù mạng mẽo ngon lành).
    Có ai bị giống tui ko và có cách nào fix ko nhỉ!?
    THKS.
+ Trả lời chủ đề
Tags cho chủ đề
Bookmarks
Quyền hạn
  • Bạn không thể tạo chủ đề mới
  • Bạn không thể trả lời bài viết
  • Bạn không thể gửi file đính kèm
  • Bạn không thể chỉnh sửa bài viết của mình
[Output: 123.94 Kb. compressed to 113.95 Kb. by saving 9.99 Kb. (8.06%)]
