MaiDinh (20-10-2009)
ZXStyles ZXReader v1.4.2 Release S60 3rd Signed Freeware
Features:
» Supported encoding: UNICODE, UTF-8, ANSI (WIN-1251);
» Automatic change of portrait / landscape mode when the phone turns;
» Fixing the desired orientation of the screen;
» Sensory management;
» Full Screen;
» Setting the font, including third-party ttf;
» Avto moving pages around;
» Office lighting - brightness is constant;
» Text - carry the words, bonding lines (cut into a line under a specific width before any editor)
» Splitting the screen into multiple active zones, each of which can hang some commands.
Changes in version:
» Fixed crash after upgrading to a chapter in the index in some cases.
» Fixed a problem starting (or rather, do not run) for Junior Symbian.
Symbian 9.1 UNSUPPORTED!
Nước biển mênh mông không đong đầy tình mẹ.
brutal_death (18-04-2010), MaiDinh (01-11-2009)
ZXStyles ZXReader v1.4.3 Release S60 3rd Freeware
brutal_death (18-04-2010), intel05 (08-12-2009), linktel (01-12-2009), MaiDinh (03-11-2009)
Smartphoneware Best Jotter v2.01 S60v3 SymbianOS9 incl K*ygen-HSpda/Unsigned Cr*cked-FoXPDA
Best Jotter allows you to write down quick notes, memos, ideas and any piece of information, organize it, and easily find at any time. You can keep your sensitive information as notes as well. Just set up a password in the application and Jotter will encrypt all your data. Additionally it's possible to export notes to a text file that you can transfer to PC. The format of this file is very simple and you can edit the file in any text editor or Excel, transfer it back and import to Jotter.
Features include:
* Organize notes by folders
* Optional password protection and encryption
* Intelligent search function
* Export/import notes to a text file
What's new in v2.01:
* Both S60 3rd edition and S60 5th edition are in one installation file now.
* 3rd ed. version catches 5th ed. version in functionality
* Help file added
* Touch enabled devices: drag-and-drop support is added to note browser view
* Touch enabled devices: toolbar actions reworked
Tôi rất sẵn lòng chia sẻ mọi thứ tôi có thể và tôi hạnh phúc vì điều đó!
brutal_death (18-04-2010), MaiDinh (07-02-2010)
Bookmarks
